Why would this happen?
Lots of reasons. Here's what to try instead:
I. cut w/ bbMPEG (see Edit section to left)
1) Demux MPEG in TMPGenc "File | MPEG Tools", choose "simple demux. This will create a video (m1v or m2v) file and an audio file (mp2).
2) Cut w/ bbMPEG
II. assuming you encoded with TMPGenc to start with. Encode source to two MPEGs. You can select start/stop points for you encode using the source range option. Click on settings | advance. Then double click source range.
Choose your stop/start points. Encode, then choose 2nd 1/2 and encode again.
If you want, you can batch encode both. Choose file | save project. Give it a name. Then give the 2nd 1/2 a diffent project name (and output file name). Then choose file | batch encode. Add both projects and hit run.
I often use batch encode to set up multiple encodes before I go to school/work and/or bed. Fairly handy.
Hope one of these helps you
Having problems trying to split MPEG-4 file
By Xax in forum EditingReplies: 7Last Post: 4th Dec 2009, 16:27 -
VOB sync problems when selecting within a file
By Fishcat in forum Newbie / General discussionsReplies: 6Last Post: 23rd Feb 2009, 12:50 -
Audio track out-of-sync with DivX/XviD media file after video was split
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2008, 03:30 -
Need to expand sound file to fix sync problems
By Calidore in forum AudioReplies: 0Last Post: 5th Jul 2007, 16:53 -
Merged file audio sync problems!
By leedownen in forum EditingReplies: 5Last Post: 14th May 2007, 01:37
