  1. Hello all, What I am trying to do is I have a small clip play as soon as the dvd player starts. From there I have a menu that links 2 movies. Then my 2 movies. The problem is after my clip ends I get this green screen which I thought should be my menu then right after that movie one starts to play. I don't get a menu to choose which movie I want. Donig all this in power dvd first just to make sure everything is working. Where is my menu and how do I fix it. Thanks all
    Apr 2004
    Miskatonic U
    Look at the connectiosn window. You should have
    1. A link from First Play to your intro clip
    2. A link from your intro clip to your main menu. If this is DVD Lab Pro, this is probably your VMG menu
    3. A link from your menu to each of your movies
    If it doesn't look like that, let us know
    Read my blog here.
  3. Thanks gunslinger I will let you know how it goes.
  4. Everything worked out great as long as I drew the connection lines manually. If I right click the first menu and linked it to the second menu all I would get on playback is a loop of menu one. Any idea's why it did that. Thanks again for all your help.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Can you post a grab of the connections window after linking the menus ?
    Read my blog here.
  6. If you have "Autoroute" ticked, it can assume the wrong thing (as I suspect this is the case), and make your links go to the wrong thing.
    Cheers, Jim
    My DVDLab Guides
  7. Ok reboot where can I find this autoroute thing??? Thanks
  8. If you don't see a tick box at the top of any menu screen, you have a different version.
    If you select a menu, you should see it at the top, untick it.
    Cheers, Jim
    My DVDLab Guides
