Ok I have been doing alot of searching and am not sure if a PCI capture card is worth the money spent. I have a canopus ADVC-100 works perfect have had for three years and have only used it a handfull of times. My wife uses it almost everyday and I have found that it is about impossable for me to get it back. My fault I got her hooked on video editing. My computer is a P-4 2.8 ghz HT with a 160gb hd 528mb ddr 3200 ram with a nivida 5600 ddr 128mb graphics card. Not the latest and gratest but holds its own.
Am i wasting my time and money on a cheaper device or should i buy a advc-50 i was looking at a V-Stream Xpert dvd PCI video capture card $35.00 shipped to my door new in the box. Have used this site for years I remember when it was vcdhelp.com Thanks for any helpful input. I am sort of on a small budget at this time other wise i would step up and buy the advc-50 with out any thought. Oh can the macrovision be disabled on the advc-110 or the advc-50 or the advc-300 I have searched but can not find this info anywhere. I am able to do so with my advc-100 Thanks again
The ADVC-50 can have Macrovision defeated, but you have to remove the 6th jumper switch from the card itself.
I can't answer for the 110 or 300, but if the 100 has this as standard, then it should follow that the next ones up should do the same!Cole
PCI or PCIE video capture card
By bigjimmpls in forum Capturing and VCRReplies: 11Last Post: 1st Jun 2010, 12:36 -
Capture analog with camcorder or ATI card?
By Onceler2 in forum Capturing and VCRReplies: 7Last Post: 28th Nov 2009, 07:25 -
Capture analog video from sony camcorder
By gthoman in forum Capturing and VCRReplies: 14Last Post: 14th Apr 2009, 14:32 -
I need a good FireWire PCI card for capturing video.
By mob in forum Capturing and VCRReplies: 11Last Post: 1st Apr 2008, 01:19 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
