Hello all,
I ran into my first .mov file (it's a movie) and can't figure how to burn it with nero 6 to a vcd or dvd. I tried isobuster and a few others to see it, but can't figure this one out. Do I need some sort of plug in? Any help appreciated. Thanks
you need to encode it to either vcd or dvd then nero will burn it. course if you would have made a little effort you would all ready knowthat.....do you not see the HOW TO section on the left?? its there fot a reason use it....it covers everything you need to know about mov to vcd/dvd....
How Big A Boy Are Ya? -
.mov is about the most stubborn format I've come across, when it comes to convertability. Only way for the .movs I've tried was River Past Video Cleaner, to AVI, that can then easily be encoded to any kind of mpg.
/Mats -
Another alternative is to convert the audio track first using Quicktime Pro to a WAV-file and then convert just the video-track from the MOV-file but the audio-track from the WAV-file using TMPGEnc with the Quicktime-plugin. This is because the Quicktime-plugin for TMPGEnc does not handle most of the audio-tracks from MOV-files.
CU
Schmendrick -
n0jam,
You can alos use Nero Vision Express 3 to encode your mov file to VCD/SVCD/DVD compliant mpeg file. Which can be burnt to DVD later. -
You can also use WinAVI Video Converter. Though sometimes it has problem maintaining the correct aspect ratio.
well why don't u directlt burn it as a data cd.i don't think nero will give a problem
Originally Posted by VenGeanCeSomehow, I get the feeling n0jam wants to play it on his/her DVD player...Originally Posted by n0jam
/Mats
How to burn avi files using nero 8?
By funkymonk in forum Newbie / General discussionsReplies: 2Last Post: 22nd Sep 2008, 02:23 -
Azureus + Nero 7 - How to Burn Torrent Files to disc????
By alao in forum DVD RippingReplies: 1Last Post: 11th May 2008, 03:36 -
How do I burn MP4 files to a DVD video using NERO Express 3
By magikero01 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Feb 2008, 09:26 -
How to burn avi files to nero
By crocker5731 in forum Authoring (DVD)Replies: 2Last Post: 27th Sep 2007, 21:13 -
Can someone tell me how to burn avi files with nero?
By trolea1234 in forum Newbie / General discussionsReplies: 13Last Post: 17th Jul 2007, 19:13
