Hey all, I just followed this guide here https://www.videohelp.com/guides.php?guideid=738#738 which I ripped my 5 minute dvd to avi. My problem is the quality of the video. It came out ok but some parts the sound chirps and its loud enough and also the video plays slow. Is there a better way to rip the dvd with better quality. My main goal is to transfer it to the web which doesnt have to be super quality but good enough to view and hear.
Any Suggestions?
Thank You
Results 1 to 10 of 10
I've had succesful results using DVD Decrypter to rip the VOBs to my hard drive, then using VirtualDubMod for conversion to AVI. After that, Movie Maker to create WMV files. Others have used VirtualDub for conversion to Divx, Xvid, etc. There should be guides for all of this in the guides section.
Good Luck. -
Rip to mpeg instead (not sure if next step accepts vobs which is why I suggest mpeg)Originally Posted by Epicurus8a
If the mpeg is sufficient for the web leave it, if not go to MS website and get the free wmv encoder. I may get flack for it but the fact is the wmv is great fomat that plays on any windows machine. -
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=VOB+to+MPG&h...or+List+Guides
Oddly this can be found in the all guides section to the left
You were just looking at the wrong one.
thanx coalman but where does it explain ripping straight to mpg with dvd decrypter? am i missing it or should i be using another program listed there?
ok i guess TMPGEnc DVD Author would be my best bet since i have the vob file correct?
https://www.videohelp.com/forum/viewtopic.php?t=224833
It's down about 3 or 4 programs.... I've actually never used the guide. Just did it. You'll figure it out.
Edit: Specific link... https://www.videohelp.com/forum/viewtopic.php?t=224833#dvddecrypterdemultiplex
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
Good quality video conversion
By Soopafreshfan in forum Newbie / General discussionsReplies: 9Last Post: 9th Aug 2011, 20:57 -
Optimum Ripbot settings for HD video quality during conversion
By mario595 in forum Blu-ray RippingReplies: 22Last Post: 12th Apr 2010, 14:28 -
Handbrake or WinFF conversion with no loss of video quality?
By sideshowmel in forum Video ConversionReplies: 0Last Post: 13th Jan 2009, 19:15 -
MKV VIDEO CONVERSION, problem with the quality of the output file.
By pay1000 in forum Video ConversionReplies: 11Last Post: 25th Jun 2008, 03:46
