Hi
Well, I must say I use DVD-Lab Pro for authoring DVD's. I have my .m2v movie and audio separately, and then after authoring, all my movies stay perfect, video and audio in complete sync.
But when converting to mpeg2, files that are 29,970 fps, I noticed that the video and audio stay out of sync...but that only happens with 29.970 fps sources! Why is that?
For example, when I have 23,976 fps sources, after converting to mpeg2, i make the pulldown, and it stays fine after authoring, but when I have 29,970 fps movies, that doens't happen.
Can anyone help here?
..thoughts arrive like butterflies..
Anyone out there to help me on this please?
..thoughts arrive like butterflies.. -
What are you using to transcode audio?
Cheers, Jim
My DVDLab Guides -
Hi
Well, I use ffmpeggui to convert the converted file (.mpa file) to ac3.
Then I import to DVD-Lab the .ac3 and .m2v files, and like I said, if it's 29.970 fps when I start watching the movie, the audio is in sync with the video, but it keeps losing sync as long as the time passes by...
Why is this?..thoughts arrive like butterflies.. -
Assuming your original source is avi, rip audio with virtualdub to .wav, transcode to ac3 in ffmpeggui, then import to dvdlab.
Encode video only (ES Video Only) in tmpgenc.
I have been doing it that way for a very long time, and don't have any sync probs.
Tmpgenc seems to have trouble with some audio, depending on it's source fps/frequency/bitrate, and this may be the case.
Eliminate tmpgenc from doing audio, and it may work.Cheers, Jim
My DVDLab Guides
Synchronize Audio and Video from Different Sources
By Bruno AUgusto in forum AudioReplies: 2Last Post: 22nd Nov 2011, 18:27 -
How do i combine a video file and audio for two different movie sources??
By Kyisha in forum Newbie / General discussionsReplies: 3Last Post: 22nd Mar 2010, 06:03 -
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 12:01 -
Mux & sync audio from different sources
By RWANDREWS in forum AudioReplies: 1Last Post: 9th Jan 2009, 10:06 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23
