I've been reading up on reeldvd and judging from the tutorial, it requires psd files for menu creation. Does anything other than Photoshop (mentioned in the tutorial) create psd files? Or am I going to have to shell out more money for Photoshop as well?
Results 1 to 10 of 10
you can also you paintshop pro, There is also programs to convert to psd format,not sure what one.
Also I'm sure it must use other image formats?I'm not to sure as i have never used that program..Good luck.
Originally Posted by celtic_druid
Anyhow give Photoimpact a try...
I've tried the GIMP and didn't like it but you can hardly complain about the price. -
Problem is though that if you make your format proprietary then it limits its use and maybe you can't sell your product, so I would imagine that Adobe made the format open, you can probably even get specs from them.
What GIMP generally doesn't include is GIF and compressed TIF support as these require patent fees. Being opensource though you can always compile it yourself.
Can u use PSD files for menus in DVD LAB PRO?
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2010, 15:02 -
need psd template for cd/dvd label
By wingfan in forum MediaReplies: 3Last Post: 22nd Dec 2008, 13:25 -
Bending a PSD in after effects
By sk8_aholic in forum EditingReplies: 2Last Post: 15th Dec 2008, 19:29 -
Jagged edges upon PSD inserting in PPro
By Vially in forum EditingReplies: 0Last Post: 12th Sep 2008, 16:34 -
Importing .PSD files into Dvd Lab Pro, and loosing image quality.
By mlong30 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 19:28
