I am compiling selections of songs from concerts in several DVDs. I know I can make copies from the finished DVD or from Temp encoded files but it seems the procedure is longer than if it will ask to insert the next disc to burn. Thanks for the help.
get dvdshrink to output to an ISO file then use your burnig software ( i would use DVDDecrypter ) to burn multiply copies
You can't. You have to use a program for authoring like tmpenc dvd author, but the files have to dvd compliant (mpegs).
Does it mean only DVD-MPEG and not the regular MPEG1 or MPEG2?Originally Posted by winifreid
faster way to make multiple home dvd copies
By DirtBikeMike in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2010, 12:37 -
Question how to make multiple cuts with DVD Shrink
By jimdagys in forum EditingReplies: 9Last Post: 20th May 2009, 20:19 -
Is it too much trouble to make Blu-Ray copies?
By timmus in forum Newbie / General discussionsReplies: 3Last Post: 20th Jan 2009, 04:53 -
ide dvd burner and sata harddrive - how do i configure?
By mshuang in forum DVD & Blu-ray WritersReplies: 2Last Post: 12th Dec 2007, 01:46 -
how configure nero 7 to start up on DVD choices
By zmartha in forum Software PlayingReplies: 4Last Post: 13th Aug 2007, 19:54
