I have bene trying to find a program that will simply convert a 24bit stereo wav file to an 8bit mono wav file. i have gone through a few programs with no luck...
dbpoweramp has the option, but the output is always a very small size and unuseable wav. i also thought virtualdub might allow audio conversion, but no matter hwo hard i look, i cant find any option to output an audio conversion alone. does anyone know of another program to do this?
Results 1 to 13 of 13
hmm i tried that one too, but the output was a useless file liek the one i got from dbpoweramp
i imported the wav and then made the settings for the conversion and hit export wav, but then the output was only 2kb.
what am i missing here to get it to output properly -
set mono mix
set rate 8k (down arrow at top of track header box)
export As Wav -
hmm ok i did all of that and now at least it did better, but it only exported a 10 second long file. the wav is 24 minutes long, is there some other setting i need to make?
let me do one a different way and list every step
set project to mono mix, project rate to 8k (verify lower left)
file open song (I opened a 4 min 44k, 16bit stereo song)
click on arrow on song header select split stereo track
make each track "mono"
under project select "quick mix"
you should now have a 16bit 8k mono file
export as wave
Now I see you wanted 8 bits, oh well starting over
project preferences then "File formats" select Wav 8bit PCM under "uncompressed export format"
you should now have a 8bit 44k mono file
export as wave -
ok this is pretty weird now lol
im trying out audacity, tried following the steps here, but whenver i go to import audio, it pops up a box saying 'importing mp3' . after it completes it, its a mono track... but i know its a stereo track.
if it makes a difference, when i looked at what type of wav it is, it said 'ACM codec not installed' . could this mean im missing a codec and that is why im having all of these problems trying to convert one song? -
How about importing it into Windows Audiorecorder then export it back out as whatever you want.
hmm i could try that. unfortunately, sound recorder is not installed on my xp system. can anyone point me to where i might redl the program to try?
I think it is a defult install,Every Xp Computer has it.Originally Posted by trooper11
Sounds as if you're trying to create a ringtone
in this case if you have a newer ver. of nero wave editor this would be possible.
Open in nero wave editor and clip the part of the file you want then file>save as>and save as a 8k mono pcm wave
done. -
Oh ok, 'importing mp3' is a different animal from a wav entirely.
5.1 wav or 6 mono wavs to 5.1 Ac3 conversion
By wturner in forum AudioReplies: 38Last Post: 24th Nov 2013, 09:26 -
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 14:36 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 23:45 -
6 mono Wav to ac-3 or other?
By dave_van_damme in forum AudioReplies: 6Last Post: 18th Dec 2008, 20:55
