  1. Banned
    Dec 2004
    SE4
    Would someone please give me an example of what id need to type in order to get all the cookies from the cookies folder onto a floppy disk?
    it needs to be a command i can type in on notepad and save as a batch file.
    cheers
  2. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Not sure if there's a command line method. I usually just go through File > Import and Export in Internet Explorer.
    Nothing can stop me now, 'cause I don't care anymore.
  3. Banned
    Dec 2004
    SE4
    thanks very much but is there ID in there about whos computer the cookies wld have come for..cos i did export and it created a text file in that text file wld there be ID of whos computer the cookies came from??
  4. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    By default it's just called cookies.txt but when you Export it, you can choose the filename and name it whatever you want, including the username or their real name or anything else.
    You SHOULD keep the .txt extension so it's easy to import it later.
  5. Banned
    Dec 2004
    SE4
    cheers, but inside what txt file when u open it.. isit likely to contain ID of the computer it was logged from say the computer was claled student or something would it come up with ID that someone would recognise it as being a certain persons??
  6. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    I exported mine and I don't see any reference to my username in the .txt file. If you want it to be identifiable, you may want to make the username the filename.
