Is is possible to use button rollovers (for example an image pops up when the button is selected) in adobe Encore?
I know that I can set a highlight layer in photoshop that will highlight a certain color when the button is selected, but if I attempt to use an image in that layer, Encore only shows you the shape of the image completely tinted in the highlight color.
I don't want this, I want to actually be able to see a complex image instead of a highlight, is this possible?
Not.Originally Posted by Kinthalis
Only highlight layer.
https://www.videohelp.com/forum/viewtopic.php?t=218913&highlight= -
You need to create a switched menu. Effectively, it's a second menu that auto activates when you give focus to a link, and displays the alternate graphic. I know you are using encore, to the details of exactly how won't be relevent, but http://www.mediachance.com/dvdlab/tutorial/switchmenu.html will explain the concept.
Read my blog here.
Only two things no good to creative a switched menu,Originally Posted by guns1inger
the menu become slowly to respond
and if you have 6-8 buttons on menu its became a mess. -
I didn't say it was easy or clean, just that it is the only way to get the effect has is after. Speed of response is as much a player issue as anything else. I have seen some players flip through switched menus very quickly, while others lag trying to seek the next page. Authoring can't really control this, other than keeping the menus to simple stills to reduce data loading.
Read my blog here.
DVDlab PRO : Motion menu, cells, missing button highlights !
By TheCap in forum Authoring (DVD)Replies: 18Last Post: 13th Jul 2011, 12:14 -
Encore subpictures - getting simple rollovers to work
By Mylo in forum Authoring (DVD)Replies: 1Last Post: 28th Feb 2011, 11:11 -
GfD button highlights
By bratpop in forum Authoring (DVD)Replies: 1Last Post: 3rd Jan 2008, 07:38 -
creating highlights for button in Encore
By newsphotog in forum Newbie / General discussionsReplies: 0Last Post: 16th Aug 2007, 18:25 -
Creating highlights for buttons in Encore
By newsphotog in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 19:19
