hi all.
ive purchased the Verbatim DVD-R Printables 50 Pack and the packaging states that it used the AZO Advanced Dye, with Datalife PLus.
I just did a media info scan to check the fye and it states that the dye is MCC. shouldnt it tell me the dye is AZO?
thanks
VJ
Don't worry about it. If the media code is MCC, then the discs are using AZO dye.
thanks for the reply mate, thanks for putting my mind at ease.
i was expecting the media ID to say AZO instead of MCC (Mitsubishi Chemicals).
also im guessing Super AZO means the same thing then? i have some Verbatim CD-R media which state that their using Super AZO, also stating a guaranteed 100year archival life on the packaging...awsome!!
thanks again
VJ -
AZO is a metallic chemical in the dye.
Verbatim DVD-R AZO discontinued?
By louv68 in forum MediaReplies: 15Last Post: 8th Apr 2014, 19:50 -
Verbatim LTH Media...Info
By New Bee in forum MediaReplies: 2Last Post: 13th Feb 2011, 05:58 -
Long-Term Storage - Verbatim DVD-R 16x (MCC) still BEST/IDEAL ?
By quantass in forum MediaReplies: 7Last Post: 29th Jan 2010, 00:14 -
Pioneer DV-400V won't read Verbatim MCC-004
By unknownsoldierX in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th Sep 2008, 14:55 -
Verbatim DL media...
By Krispy Kritter in forum MediaReplies: 13Last Post: 2nd Sep 2007, 21:29
