RC2 won't start for me, have been using RC1 today without any probs, uninstalled and installed RC2 and get the following error.
Version:SVCD2DVD 2.0 RC2
Type: System.ArgumentException
Source: mscorlib
Message: The path is not of a legal form.
InnerException:
StackTrace: at System.IO.Path.nGetFullPathHelper(String path, Char[] invalidPathChars, Char[] whitespaceChars, Char directorySeparator, Char altDirectorySeparator, Char volumeSeparator, Boolean fullCheck, String& newPath)
at System.IO.Path.GetFullPathInternal(String path)
at System.IO.FileInfo..ctor(String fileName)
at x3284ccece41ee22b.xece14591aa1abb99..ctor(Guid xe423f530b92aa05c, String xd168ac2ed64c4662)
at x3284ccece41ee22b.xece14591aa1abb99..ctor(String xd168ac2ed64c4662)
at x3284ccece41ee22b.x210ff09a2516b1a7.x21f497a09c280 fd5()
at x3284ccece41ee22b.x210ff09a2516b1a7.xc456b78441ff1 c49()
at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.ThreadContext.RunMessageLoopI nner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.ThreadContext.RunMessageLoop( Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322 395(String[] xce8d8c7e3c2c2426)
Have tried uninstalling and reinstalling but no joy.
Using WinXP Pro SP2, P4 2.0 Ghz, 1024MB Ram.
Rock On
Mmm. You found a bug. I think you had custom menu audio set in the menu options (for RC1) but with no audio file specified. The solution for the time being is to change the following in your registry:
HKEY_CURRENT_USER\Software\Badgersoft\SVCD2DVD 2.0\Settings\Menu\AudioEncoding
from Custom_mpa to Silence_mpa
or use RC1 and change the menu audio settings that way: either to Silence or give the custom default a valid file.
Let me know if this resolves the issueSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Excellent. I have fixed it for the next release too.... Thanks for the headsup.
Weird DVD Flick startup error
By Klatuu in forum Newbie / General discussionsReplies: 5Last Post: 14th Aug 2011, 02:03 -
Vdubmod Crashes On Startup Kernel32 Error
By Konfusion in forum Video ConversionReplies: 10Last Post: 31st May 2009, 16:19 -
qustion about Windows startup error
By jimdagys in forum ComputerReplies: 4Last Post: 18th Apr 2008, 06:57 -
Error on Startup SVCD2DVD 2.5
By jenevans33 in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 05:05 -
Error on startup
By bush in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 22nd May 2007, 19:30
