While the merge feature has worked well, i've come across a problem when trying recently. The program will finish exporting up to 99% then i'll get some errors: "Incorrect Video_TS file format" and "Can't write VMG".
And then program will quit and not finishe. How would i fix this?
Both discs were properly ripped and untouched. No Progs. like DVDshrink were used, before attempting the merger.
Are you using the last version, 2.6.4?
I had some merging problems with prior versions and they disappeared when I changed to the last one.
Anyway, that specific problem of yours is new for me. -
so you finally decided to fork out the $40 then?
I've never heard of your errors but maybe someone has at the DVDRemake forums as djelimon mentions. All I would suggest is you blank as much as you can and do some mini merged DVD's to see if you still get the error. If not then try adding a bit more content each time until it does barf
this may help you isolate the problem
Yeah and the disc merge feature is the ONLY thing i use it for. It seems to have been well worth it though.Originally Posted by MackemX
Being able to put two discs onto 1 with menus to each fully intact is a great feature. -
Problem solved works now. I think it might have been because i did not unzip/extract the program from the zip file first, with a program like Winzip, before useing it.Originally Posted by MackemX
Either way it worked ok.
I have an annoying problem with my dvd burner.
By roomgrey in forum DVD & Blu-ray WritersReplies: 6Last Post: 19th Oct 2010, 14:43 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 11:31 -
how to combine dvds without using dvdremakepro
By Onceler2 in forum DVD RippingReplies: 3Last Post: 3rd Mar 2008, 14:58 -
DVDRemakePro issues
By tsmr in forum Authoring (DVD)Replies: 1Last Post: 2nd Mar 2008, 16:30 -
DVDReMakePro - Nero compliance error?
By Sephiroth666 in forum DVD RippingReplies: 7Last Post: 1st Dec 2007, 10:15
