I just did 4 pass CCE 2.5 with DVD Rebuilder which took like 12 hours !!!! & did DVD Shrink which only took 5 hours .
& the results were terrible, I would think 4 passes would be enough, afterall, i can do a 2 pass vbr in tmpgenc & at 1600 & have good quality !!
this video was 4hours long, I wanted to cram it onto 1 DVD.
DVD Shrink did just as good as the CCE !!!!!.
what am i doing wrong ?
Irregardless of the number of passes, IMO you're never going to get anywhere near decent quality using any encoder using roughly 2300kbps (got it from a bitrate calculator) for full D1 (720 X 480). However, change your frame size to half D1 (352 X 480) and I'm confident you'll find the results much more palatable. All things being equal, as good as DVDShrink is, a re-encode will always get my vote as a better option if we're strictly talking in a purist domain. In practice, I swear by DVDShrink for most jobs as I don't find the difference noticable to my eyes.
If in doubt, Google it. -
I just started useing CCE this past week and it does take a long time, but my results have been fantastic. I do it overnight while I sleep and it only takes 5 hours or so for most of my DVD's. I still love DVDShrink and use it for movie only backups with little compression.
Oh, I only do 2 pass. Not sure 4 pass would would be worth the extra time from some of the posts that I have read.NEC ND3500A/G
Unproper and proud of it -
I use CCE via DvdRB and use many passes. I always half d1 the extras (if i havent ripped them with vobblanker already) with maybe a 25% quality cut (depending on the extra).
The only reason that I use 10 (9 + 1 .vaf pass) total passes is that I set it up before I go to bed at night. I work days and don't get back to my comp until after I get off at around 5 pm. Almost always it's finished encoding and I have never had a quality issue that way. (anyone who says CCE diminishes quality after 4 or 5 passes is wrong...from doom9: geffroman - OK... Is there a scenario where an extra pass could degrade the final quality...? or is it just a matter of possibly no gain for all the extra time spent...?
wmansir - It will never hurt, just waste time.
http://forum.doom9.org/showthread.php?s=&threadid=74356)
The only times that the encode isn't complete is when doing episode discs. I don't do batch encodes (not enough HDD space ) otherwise I would set 5 passes for 2 encodes each. I guess.Boy do I love my avatar! -
10 passes?? whew, you do have some time to waste.
I'll bet you won't see a difference between a two pass and your ten pass.
If you do, please post so I can see it too. -
You guys have a much larger budget for your video hobby (job) than I do to be able to afford CCE SP (two-grand). I specifically bought CCE Basic ($58 ) to use with DVD-Rebuilder, and since have started using it (over TMPGEnc-Plus) as my encoder of choice. CCE Basic VBR is limited to 2-passes.
I'm very please with the speed and quality I get from CCE Basic 2-pass VBR.
For backing up DVDs, I'll use DVD-Shrink if compression is 90% or better. Otherwise, I'll use DVD-RB w/CCE Basic (2-pass VBR).
To be honest, I really can't tell a difference between DVD-Shrink and DVD-RB w/CCE but It just makes me feel better using DVD-RB when compression falls below 90%.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
For only 5 or 6% reduction, should I use CCE/HC or Shrink?
By stanley_a in forum Newbie / General discussionsReplies: 4Last Post: 22nd Dec 2008, 17:54 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
