Closed Thread
  1. Ok this is my last call for help after this no more I give up. I have two avi files I want to join but sometimes I get a data error or something that says I can't joing them. Well how do I get around this and fix it so that I can burn it to dvd. When I use dvd Santa I get an error and it make me shut it down. I could convert them using win avi as batch files if it would work. Virutal Dub won't let me joing them at all or append them. I need help so please someone lend a hand.
    Thanks in advance
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Suggest you supply more info in your original thread, "I want to join to AVI's and it won't let me" is not enough, plus double posts are frowned upon. Someone responded to your original thread but you have left them hanging....
