Hi,
I have some DVD that were sent to me. The DVD's are AVI files burned with pinnacle studio and are over 4GB each. *sigh*
When you play it in windows media player you can watch a couple minutes then you get:
File is not in the correct format: error(8004022F)
When I analyze them in gspot I get the error:
Corrupt AVI header /RIFF:AVI and then an offset and value are given.
Is this cause the file is over 2GB?
I have virtual dub and when I insert the disks it begins to try and fix the header. It ran for over an hour but I assume it is because the file was on a DVD and not on the drive where it could add the missing blocks, is that right?
I can't copy the file to my hard drive to try and fix it either. When I try to copy the file to my hard drive it errors out. I can't even copy it using a DVD burner. I don't have pinnacle studios to even see if it will play in there, so how can fix this?
Thanks so much from a desperate Jr Robotics coach
Carla
The disk is corrupt and can't be read properly. Check for scratches, fingerprints, etc. You could try reading it on other drives -- some do a better job than others. Other than that you're SOL.Originally Posted by adiasangel
Nope, the disks are fine. The disks were even varified before they were sent to meOriginally Posted by junkmalle
When you copy a file from a DVD there is no attempt made to analyse the contents. If you can't copy the file your DVD drive simply can't read the disk.Originally Posted by adiasangel
We have tried to copy these disks to the hard drive using 3 different DVD roms on 3 different OS's. Any other ideas?Originally Posted by junkmalle
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
Checking avi file corruption
By Igniss in forum Newbie / General discussionsReplies: 4Last Post: 11th Dec 2009, 10:43 -
VirtualDub can't find an audio compressor while GSpot can for my avi. Help!
By yosarian in forum AudioReplies: 13Last Post: 2nd Dec 2008, 09:01 -
.AVI File Corruption.
By Froberg in forum Newbie / General discussionsReplies: 9Last Post: 28th Jul 2008, 05:56 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 11:26
