Hello,
Ok I've seen this in some action movies over the years and have wondered how it happens:
What gives????? That purple highlight off of the flare - how does that get recorded by the camera????? I thought that HOLLYWOOD movie cameras would be superior and eliminate any such anomalies????
Kevin
Results 1 to 29 of 29
AnonymousGuest
yeah,you got some on your avatar as well.
This was just like the snake scene in Radiers.They used a piece of glass to separate the actor from the dino.Hence the reflection. -
Hello,
Actually the avatar is from PHIL COLLINS' IN THE AIR TONIGHT Music video
So how does it happen???? Is it the moisture content in the atmosphere??? Obviously that scene from JURASSIC PARK is in the rain. But the INDIANA JONES scene you refer to wasn't. What's the factor for it????
AnonymousGuest
The glass is wet and much thicker than the "snake"
scene.It has to be thicker due to the sheer size of the dino. They may have had to use bulletproof as well for the same reason.This would probably cause the "red" shift you see.IMO -
Hello,
Hmm.... Could be.....
Though in those JURASSIC documentaries I don't seem to remember them having to place GLASS between them in the TREX scene.....
Originally Posted by Dr.Gee
Quit screwing with him Gee --
Why would they need a piece of glass between a fake T-rex and the actors? You know it's not lens flare and that it's actually the "cold cathode" light mod they did on T-Rex. -
Woah... How the hell could GLASS hold back a fully grown T-Rex? This is absurd! Everyone knows that the Dinosaurs in Jurassic Park were HEAVILY fed so they would be less agressive towards the actors and no glass barriers would be necessary. The lens flare is caused by the Mineral Oil that was smeared on the animals (which is light reflective) to give their scales a "shiny" effect. I am surprised the director chose this route.Originally Posted by Dr.Gee
Hello,
Hmm.... you mean the animatronic puppet of courseOriginally Posted by blazey
Well it seems to be getting closer to being answered. Seems to be the best one so far.....
Thanks for the input guys
Hello,
:P :P :P :P :P
That's not the original version
There's nothing there. You're seeing things.
Nothing can stop me now, 'cause I don't care anymore. -
Hello,
Look back at the original snap shot on the first post.
Get out your copy of JP1 and watch the TREX scene again. It's right there.
I think it's even on the JEEP top rack Headlights when NEDRY gets killed by the DILOPHASORAUS - sorry if I spelled that wrong
AnonymousGuestNo,no,no.All wrong! You suggest mineral oil,but how sir ,would account for the purple shift. Mineral oil clearly causes a green shift in these situations.Originally Posted by Blazey
Especially since the dino is coming toward the camera.Duh. -
I think it's there to give Yoda a reason to up his post count, it was well thought out in advance.
Hello,
Dr Gee - You care to translate that equation for the math illeterate????
And coalman - no it's just something that I was curious about
You know, this is so typical. If you are UNINFORMED, why answer? A Dinosaurs vision is comprised of different optics than humans. They cannot see the same colors as we do. Thusly, a purple light, shined at the animal is used to limit it's vision in an attempt to make for a safer filming environment. Just look at this:Originally Posted by Dr.Gee
As you can CLEARLY see, that accounts for the purple lens flare in this instance. It is a little known fact though, that Jeff Goldblum was eaten during filming and his stunt double has taken over his identity. -
No big loss.Originally Posted by BlazeyNothing can stop me now, 'cause I don't care anymore.
AnonymousGuest
My good man,lest we not forget it is raining.
Relativistic Aberration
In classical physics, the aberration of light works just like the aberration of rain--it depends on the ratio of the speed you're going to the speed of light. It's only because the speed of light is so great that it takes precise measurement of the position of stars to make aberration apparent. Classical physics, then, predicts that if we were to travel at the speed of light we'd measure the aberration of light from a source orthogonal to our direction of travel to be 45°.
But that implies we could continue to accelerate past the speed of light and measure greater and greater angles of aberration, just as the TGV does when it exceeds the speed at which the rain is falling. Not possible--in special relativity no material object can attain the speed of light. When the Lorentz transform is applied to the aberration of light, we discover that the the aberration measured by an observer travelling at velocity v for light from a distant source at direction phi in the rest frame is:
Hello,
So that's why LOST WORLD sucked with him as the star?????
I'm glad they were able to bring SAM NEIL in for JP3 - BIG DIFFERENCE there
Kevin
DR GEE -
Why didn't you just agree with one of my earlier guesses that it had to with moisture content instead of the physics????? Wow - definetely over my head.....
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Hello,Originally Posted by Dr.Gee
Ok thanks for pointing that out.
So the flare can happen even when its not raining??? I mean like if its really foggy or right after a rain??????
Hello,
Thanks for the info
this is the dvd backup formula
1+1=3
Hello,
Thanks for the link TGPO
Very informative
God willed it and it was so. The purpose was to make those, who pay too much attention to the details of a movie, stand out so others may have the pleasure of laughing at them.
AnonymousGuestBJ-Shouldnt that be -i? I guess it depends if you are using +R or -R.Originally Posted by BJ_M
Lens Question
By budwzr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 29Last Post: 6th Aug 2011, 11:01 -
Lens Help?
By MurbeckJackson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 30th Jan 2011, 16:41 -
Camera or Lens?
By andy33 in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2010, 20:55 -
Fisheye Lens
By JakkOne in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th Dec 2008, 01:10 -
Cleaning the lens?
By Digiface in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Sep 2008, 10:27
