Need something that is very end user friendly, preferably one that the user can load the split files into a single directory and click the exe which will also check the split files for corruption, that they are all there etc.
I need it for a large file on my website and I want to make it as acessible to everyone as possible. Splitting it is my only choice.
Hello,
Can't WINZIP split files into an executable??????
I like MaxSplitter. FREEWARE
Bahaha... check out the FAQ:
JSBQ: I've tried to split .avi and .mpeg files but afterwards, the pieces just won't work! What option will I set to make this possible?
A: Well, MaxSplitter isn't designed to split files like movie files. MaxSplitter won't corrupt any information, but the pieces must be merged back together before the movie can be played. The reason is this: all files contains a header, which is placed first in the file. So when MaxSplitter splits the file, the header remains in the first file, rendering the second (and any other) file unreadable unless you merge them back again. As for .avi files, all files, even the first one, will be unreadable because the header contains information about the filesize. If it doesn't match, it will fail. I recommend using some of the tools specifically designed for these purposes: www.vcdhelp.com -
winrar? I'm not sure if you can also do a check of some sort
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 10:35 -
anyone interested in creating a new app?
By deadrats in forum ComputerReplies: 3Last Post: 17th Jul 2011, 07:28 -
good free DV (firewire) capture app with on the fly conversion
By a1s2d3f4 in forum Capturing and VCRReplies: 33Last Post: 14th Nov 2010, 12:31 -
App to trim .flv files?
By brassplyer in forum Video Streaming DownloadingReplies: 1Last Post: 13th May 2008, 01:33 -
Can anyone suggest a GOOD app to backup my computer data?
By Hittz in forum ComputerReplies: 14Last Post: 4th Jul 2007, 13:37
