Hi gurus
After scanning through ,most of the threads, decided to post one for myself.
The Problem: My VCD does not have proper motion, it is seen like what one sees in TMPGEnc while encoding and sometimes it gets struck and shows still picture. There no sound as well.
Let me tell you what I did
Captured my video from panasonic(NTSC) camcorder using Matrox Marvel G450 eTV capture card
Used TMPGEnc to cut the unwanted and then encoded it using the same by using the VidoCD(NTSC) template.
Used Nero 5.5.5.1 initially to burn the VCD then tried using Nero 5.5.2.4 as I saw a post saying that there is some problem in 5.5.5.1. But the result is same. I used burning at 2x though my writer supports up to 8x.
I have used Nero to copy some movie VCD to the PC and have burned them to my CD-R and played in my VCD player
So there is no problem of playing VCD on CD-R on my player. I feel the problem is with the encoding. I have followed all steps given in the How to use TMPGEnc. I even changed the
VFAPI plug-in so that AVI VFW Reader has highest priority.
For good sound I can use toolLame. But what to do when there is no sound atall.
Could you please help me to get good VCD
If some is ready to help me on YM, I am online in at asraj_oracle
Thank you
Steve
Results 1 to 1 of 1
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 09:41 -
Which authoring software has good motion wedding menus?
By sterankin in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2010, 04:21 -
// Boston ( motion + sound + code ) :: April 1st-5th \\
By mgchicago in forum Latest Video NewsReplies: 0Last Post: 17th Mar 2010, 15:03 -
what's a good sound card to use for my captures?
By kukuo522 in forum Capturing and VCRReplies: 4Last Post: 3rd Aug 2008, 20:53 -
Why New Music Doesn't Sound As Good As It Did
By MeDiCo_BrUjO in forum Off topicReplies: 5Last Post: 12th Jul 2007, 17:44
