This is a wonderful program that gives true lossless compression of wave files.
Unfortunately it hasn't been updated for XP - I get an error during install that says:
"c:\windows\system32\autoexec.nt. The system file is not suitable for running MS-Dos and MS Windows application. Choose close to terminate the application"
Anyway to work around this to force it to run in xp environment?
thx.
http://www.5star-shareware.com/Windows/Music/WAVPlayersandUtilities/wavezip.html
Have you considered using say Monkey audio or FLAC instead? Also optimfrog, wavpack, wmv9 lossless, etc. There really is no shortage of lossless audio compressors.
