I've been trying to help a friend clean up her computer. The OS is Win 98SE. Using Lavasoft Ad-Aware and Spy Bot and Norton we have cleaned up everything but one process identified in Ad-Aware under Vendor as VX2. It shows the location as being in the Windows System folder as bcnbngys.exe I have tried to rename and delete this file, but it says Windows is using it.
We downloaded the add-on recommended by Ad-Aware for VX2, but after running the add-on we were not allowed to click on "clean".
We have manually deleted everything that Ad-Aware found in the registry for this, but we can't get rid of this exe program that Ad-Aware finds. It runs in the background and End Task won't stop it. Anyone have any suggestions? We hope to try again next weekend.
Thanks in advance
Results 1 to 10 of 10
Are there any suspect files showing up in MSCONFIG?
Nothing can stop me now, 'cause I don't care anymore. -
I read the other day that spysweeper get's rid of it completely.
You might give spysweeper a try. -
Turn Off System Restore
Restart PC in Safe Mode
Run Spyware Killing App of Your Choice
Restart PC in Normal Mode -
If none of those work there's a specific tool called VXfinder that works great for getting rid of that %#@$$@. I know it was impossible to remove via normal spyware apps when I tried to remove it from a friends machine.
Thanks everyone. There are some great suggestions here that we didn't try. Running in safe mode is one of them. I didn't think System Restore existed in Win 98SE. I'll look for it. I am going to check out the other software suggestions too.
Thanks again. I'll let you know the outcome. -
Originally Posted by tryintoo
It was introduced in Windows Millennium Edition or Windows M.E . for short. -
YIKES ! Sorry, I didn't read the first post carefully enough. Didn't see you were running 98.
Soopafresh I tried your method this morning when my friend called me and it worked. Ad-Aware was able to delete this thing while in Safe Mode. She double checked after restarting the computer normally and it was gone.
Thanks so much. -
Just repeating what I learned from the folks on this board. Glad to hear it worked.
Can't Get Rid of Noise
By EmpireStrikesBack198 in forum RestorationReplies: 6Last Post: 9th Mar 2010, 06:21 -
getting rid of the letterbox
By jagsman in forum Video ConversionReplies: 4Last Post: 16th Oct 2009, 16:03 -
Getting Rid of PC Heat
By adalect in forum ComputerReplies: 29Last Post: 4th Jun 2009, 03:05 -
Getting Rid of Subtitles
By macbuz in forum MacReplies: 4Last Post: 16th Jan 2009, 19:09 -
getting rid of vista
By sue1951 in forum ComputerReplies: 12Last Post: 6th Aug 2007, 21:53
