I recently had my Super 8 film home movies professionally transferred to mini-DV. I would like to edit these mini-DV's and output back to tape to create an edited mini-DV master. What software package will best handle this task with either no or minimal re-encoding.
Derek
Results 1 to 10 of 10
Media Studio Pro is one. All the high end editors will have the print to tape option, or should. Not aware of a cheaper app that does that.
Does Vegas Movie Studio re-encode when it prints an edited DV file to tape?
Derek -
It will only reencode new footage. Straight cuts do not constitute new footage. Cross fades, adding a text overlay, changing colour, saturation, brightness etc will all cause a reencode OF THE AFFECTED FOOTAGE only. This goes for any DV editor worth it's salt - Premiere Pro, Media Studio Pro, Vegas and Vegas Movie Studio.
If it is only simple cuts, Windows Movie Maker might even be enough - it's free too.Read my blog here.
Virtual Dub , Direct Stream Copy
Simple , effective , free
http://www.virtualdub.org/docs_processing
EDIT : Missed the "print to tape" on the question as i only 'cut' DV back to harddrive storage. No print to tape with Virtual-D.
Perhaps a trial of the above mentioned (app's) may work for the transfer back. -
Use SolveigMM AVI trimmer. It is especially efficient for DV type1 and type2. It's free, has very simple GUI, very fast, since doesn't use any decoding/encoding techniques.
http://www.solveigmm.com/?Products&p=AVITrimmer -
It's not an editer, but WinDV can write to your mini DV tape. So you'd have to edit with another program, save as a DV-AVI then use WinDV to send to your tape. I sometimes use this method to make sure my editing software isn't reducing the quality of the un-edited footage. There could well be another free/inexpensive program to do both editing and send to tape, but I don't do it often so i haven't looked at other methods.
I believe that Ulead Videostudio 8 will also do what you require, again only re-encoding if you create effects or transitions or the like.
Regards -
Keep in mund that if you apply filter to the whole clip (e.g. levels or color correction) then the entire clip will reencode.
AVCHD editing without re-encoding
By cheerful in forum EditingReplies: 1Last Post: 28th Nov 2011, 03:21 -
Editing without re-encoding
By Gamer6 in forum Newbie / General discussionsReplies: 11Last Post: 2nd May 2011, 14:23 -
Why no AVCHD editing without re-encoding?
By digitalfreaknyc in forum EditingReplies: 6Last Post: 15th Sep 2009, 19:14 -
MPEG editing without re-encoding
By AlanD in forum EditingReplies: 3Last Post: 23rd Nov 2007, 04:52 -
Editing versus Encoding
By SCDVD in forum EditingReplies: 10Last Post: 5th May 2007, 19:04
