My guess is that the higher the framesize, the lower the quality given the same bitrate (ex: 5500kbps), since there's more "realestate" to assign the bitrate to.
My question is... I'm capturing Hi8 analog using a Canopus ADV 100 device.
What is a recommended Framesize for the project?
Capture to DV type 1 or 2 (which depends on the software, most support both) I don't think there's a choice but it should be 720x480
Capture Hi8 via a digital camescope and firewire
By SearchQuality in forum Capturing and VCRReplies: 24Last Post: 11th Nov 2011, 18:43 -
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 10th Jun 2011, 23:05 -
No audio capture from Hi8 camcorder to PC
By dimtechno in forum Capturing and VCRReplies: 0Last Post: 20th Mar 2009, 15:50 -
Capture Hi8 using what resolution?
By chrishallowell in forum Capturing and VCRReplies: 2Last Post: 3rd Oct 2007, 11:57 -
Choppy capture from HI8 in Premiere
By tmann in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2007, 14:24
