  1. Hey, for some reason I am unable to burn any dvd's.
    The problem started when my nec 2500 started playing up. This was replaced to a pioneer (not sure model) and everything worked fine (albeit slow). Finally we got a replacement with a sony drive from a computer shop. I'm pretty sure the sony drive was also a liteon, just branded sony.
    What happened, was the disc would burn a bit, then everything would hang.
    So, finally they sent out a brand new drive. The liteon SOHW 832S.
    I updated firmware and everything, but the same thing happens.
    I have tried burning 1:1 discs, via 4X, 2X. Also from image file 4X and 2X; and as you can imagine neither works.
    I also just decided to (whilst typing this) check how burning an image through alcohol 120 would work and 0.0%-0.05% burnt at 0.2X and then went down to 0X.
    Please help I'm going crazy here unable to determine what the hell the problem could be and why its reoccuring.
    P.S. My comp just froze badly and eventually unfroze. Here is the logfile from alcohol.
    ####################### Dumping/Recording Progress Log #######################
    11:28:29 Processor info: Intel(R) Pentium(R) 4 CPU 2.40GHz (2392MHz)
    11:28:29 Memory Available to Windows: 523,548 KB
    11:28:29 Memory Buffer size: 128 MB
    11:28:30 Image file loading: D:\Games\UEFA_Champions_League_2004-2005-PAL-XBOX-SPARE\suefacl0405.iso
    11:28:30 DVD Source Info: Session: 1, Track: 1, Length: 1.71 GB / 199:50:14
    11:28:35 (E LITE-ON DVDRW SOHW-832S(1:1): Recording Method/Speed
    11:28:35 Recording - DVD DAO - 2.0X (2760 KB/Sec)
    11:33:49 (E LITE-ON DVDRW SOHW-832S(1:1) - [Write ERROR] LBA: 5136, Length: 16
    S:KEY - 02/3A/00 - "Medium Not Present"
    11:33:49 (E LITE-ON DVDRW SOHW-832S(1:1): Recording failed!
    11:33:49 Error message: [02/3A/00] - Medium Not Present
    11:33:49 Image file loading aborted!
    11:33:54 Something is wrong with the recording procedure!
    Please check the log file and report any errors to Technical Support.
    ########################### Options Setting ###########################
    Devices control interface: Default Driver Control Interface
    CPU Priority Level: Normal
    Memory Buffer Size (MB): 128
    Examine the accuracy of data read from physical device: Yes
    Turn off "Auto-Select best write speed" function if possible: No
    Overburn disc(s): No
    Fill memory buffer before recording discs: Yes
    Ignore Media Type: Yes
    RMPS (Recordable Media Physical Signature) Emulation: No
    BAD Sectors Emulation: No
    Sub-Channel Data Fixed & Emulation: No
    Laserlock Emulation: No
    Current Language: English
    ############################ Device(s) List ############################
    (E LITE-ON DVDRW SOHW-832S (atapi, Port 1, Bus 0, Target 1, Lun 0)
    (F PIONEER DVD-ROM DVD-115 (atapi, Port 2, Bus 0, Target 1, Lun 0)
    (G ELBY DVD-ROM (ElbyVCD, Port 0, Bus 0, Target 0, Lun 0)
    (H AXV CD/DVD-ROM (a347scsi, Port 3, Bus 0, Target 0, Lun 0)
    ################## Detailed Information of Device(s) ##################
    (E LITE-ON DVDRW SOHW-832S(1:1) detail information.
    Vendor Identification: LITE-ON
    Product Identification: DVDRW SOHW-832S
    Production Revision Level: VS0E
    Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), TAO, DVD DAO
    BURN-Free Technology: SMART-BURN
    Auto-Select best write speed: SMART-BURN
    -* Note: This information below is provided by the unit, it might be inaccurate. *-
    -* This software does not use this information! *-
    Removable media: Yes
    Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
    Response Data Format: 02h
    CD-R Read/Write: Yes/Yes
    CD-RW Read/Write: Yes/Yes
    Read CD-R Fixed Packet: Yes
    Test Write: Yes
    DVD-ROM Read: Yes
    DVD-R Read/Write: Yes/Yes
    DVD-RAM Read/Write: No/No
    Audio Play: Yes
    Composite Audio and Video Data Stream: No
    Digital output (IEC958) on port 1 Supported: No
    Digital output (IEC958) on port 2 Supported: No
    Mode 1 Form 2: Yes
    Mode 2 Form 2: Yes
    Multi-Session: Yes
    BUF: Yes
    CD-DA Commands supported: Yes
    CD-DA Stream is Accurate: Yes
    R-W Supported: Yes
    R-W De-interleaved and Corrected: No
    C2 Pointers Support: Yes
    ISRC Supported: Yes
    UPC Supported: Yes
    Read Bar Code: No
    Lock media into the drive: Yes
    Currently drive Lock state: Unlocked
    Prevent Jumper: No
    Eject Command: Yes
    Separate volume levels: Yes
    Separate channel mute: Yes
    Changer Supports Disc Present: No
    Software slot selection: No
    Side change capable: No
    P through W in Lead-In: Yes
    Maximum Read Speed Supported (with current disc): 40X (6000 KB/Sec)
    Maximum Write Speed Supported (with current Disc): 40X (6000 KB/Sec)
    Current Read Speed Supported (with current Disc): 40X (6000 KB/Sec)
    Current Write Speed Supported (with current Disc): 40X (6000 KB/Sec)
  2. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Are you running in PIO or ATA mode?
    :star: :star: :star: :star:
    Archived DVD Scans
    Nero V ImgTools V Decrypter
  3. Member Gritz's Avatar
    Jan 2003
    If your computer is freezing up you may have more serious problems ... like adware, or a virus, not defragged, or lack of cache space. I don't see any description of your system under your profile so we can't see what's driving your system ... like cpu, memory, hard drive/drives, mobo, etc ... but I do see 4 optical drives. That could mean possible problems with the "master" and "slave " jumpering relationship. If that's correct I'd start as simple as possible .... Disconnect all optical drives except the new LiteOn and give that a try. Try defragging, or adding more memory. With the number of replacements I suspect the problem is not your optical drives .. but something more basic.
    "No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
    Nov 2003
    Moreno Valley, Ca
    Simular problem with 2 new nec 3520a burners installed in Compaq Celeron 2.5mhz
    If set to use dma if available, sys sets to mode2 = no media reconized
    If set to use PIO only, all media reconized but dvd burrn is only 1.7x
    The Comaq uses a intel 845 chipset, support had me flash the bio and some other stuff and finally shipped it back, waiting for return but not hopeful. Same burner in old 600mhz sys burns 8x 4g=7:12 min
