  1. I need life after Nero, which has given me nothing but headaches lately. I tried to install roxio twice, it froze the computer on the reboot and never finished the installation. I need something easy and reliable.
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    DVDdecrypter, iso read - iso write.
  3. Alcohol 120%....Nuff said.
    Sabro
    www.sabronet.com - It's all you need...to know
  4. samijubal, what is that you are exactly trying to do, please elaborate. There is life after Nero !
  5. Banned
    Sep 2004
    Inner Circle of Thought
    Yep
  6. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    what version of Nero are you using and what process are you using to actually copy the DVD's?
    as sanjayk mentions we need more info from you
  7. 6.6 and 6.135 or whatever it is. I put the DVD-R in and hit the copy button. it worked for hundreds of discs, then one day it decided the burner buffer wasn't going to work anymore. If I use DVD Shrink the buffer works, I can tell by the lead out, but shrink takes too long to analyze a DVD-R, about 5 minutes. Decrypter seems to work much better than Nero, so I'm good.
