  1. im trying to burn harold and kumar and the forgotten using dvd decrypter and dvd shrink but for some reason it doesnt work.
    i have never used these programs before. i usually use dvdx copy. everytime i burn something it says an error. like illgal disc or something.
    i decrypt the dvd using decrypter and then shrink it using dvd shrink and while its analysing it says not decrypted on the top right. then i try to burn it with nero and dvd decrypter but it gives me errors.
    can somone walk me through both programs and what settings it need to be on or whatever or show me a help link that i can read. i need step by step instructions...
    please thank you
  2. I'm guessing you haven't done a search in the Guides section. There's quite a few guides available in using both programs, better than what someone could do in trying to walk you through it with a message.
  3. Member blinky88's Avatar
    Mar 2004
    Australia
    Get the latest version of DVD Decyrpter and I think that will solve your problem. By the way, Decypter and Shrink is all you need.
    Also, there are many discussions within the various forums on the subject of backing up the forgotten.
