Results 1 to 14 of 14
  1. Version 0.5.2 released!
    Changes in new version:
    * Better compression (up to +10%)!
    * Compression speed increased 2.5 times!
    * Added YV12 support. Now taking as input RGB24, RGB32, YUY2, YUYV and YV12.
    * Now works in Adobe Premiere.
    * Controllable compressing speed.
    * P-frames can be disabled, key-frames max interval can be set.
    * VirtualDub jobs support.
    * And main advantage - new MSU photo!
    http://www.compression.ru/video/ls-codec/index_en.html
    We remember, that we promise 5 times faster version, but this release only 2.5 times faster (we work on lossless compression too). Now we will make it faster again!
    Enjoj!
    Please mail us if any problem!
    With regards
    Dmitriy Vatolin
    http://www.compression.ru/video/ (News: new metrics and WMP vs JPEG-2000 comparison)
    Senior editor of Compression-links.info
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    thanks DmitriyV - love your stuff ..
    did you ever get that HD bug fixed with some of your filters ?
  3. Originally Posted by BJ_M
    Thank for warm words!
    Sorry, maybe I miss some message. What bug?
    With regards
    Dmitriy Vatolin
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    the deblocking filter crashes on large resolutions -- so did the sharpen filter i believe ...
  5. Originally Posted by BJ_M
    Deblocking 2.0 (released yesterday) has this problem?
    With regards
    Dmitriy Vatolin
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    i'll check --
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    i was able to crash virtualdubMOD everytime with a standard 2048x2048 image size and either (or both) the sharpen filter and deblock filter ...
    avi was huffyuv, compression was to huffyuv (i tried a mpeg2 input and mjpeg output also) .. other filters i tried worked fine ..
    1980x1080 did not seem to crash it as much (it used to i thought) .
    v-dub would just close most of the time - so i couldnt get a error report ..
    machine is a P4 2.66 with 1.5gb of memory ..
    not overclocked ... very very stable system ..
    i tried this also last year on a dual xeon and same problem ..
    Jul 2002
    Up in yo' bitch.
    How do you call a compression algorithm lossless? Isn't that the very nature of compression; to remove things that aren't noticible thus creating a smaller file?
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
    not always
    zip, rar, lzw, huffman, Burrows, Wheeler and run length are examples of lossless compression ....
  10. Originally Posted by BJ_M
    Very good bugreport, thanks! We will test and try to reproduce and fix it!
    With regards
    Dmitriy Vatolin
  11. Originally Posted by DmitriyV
    We reproduce bug with Deblocking! Thanks! Waiting for update.
    But we cannot reproduce bug with sharpen...
    2048x2048, huffyuv in, huffyuv out, old sharpen, new sharpen (will be released soon). VDMOD (1.5.10.1 build 2366), VDMOD (1.5.10.1 build 2439), ordinary VD. No crashes...
    New sharpen will be 6-8 times faster, so it's resonable waiting for it and try new version!
    Thanks for good report again!
    With regards
    Dmitriy Vatolin
  12. Член BJ_M's Avatar
    Jul 2002
    Canada
    i look forward to the new versions, thanks again for your excellent filters .. and I enjoy reading the info in your various web sites ...
  13. Originally Posted by BJ_M
    I experienced VDub crashes with the 2.0 deblocking filter as well. It only crashed if I had the V or U enhancements checked. Worked ok if these were not selected.
    Couple of questions about deblocking filter. Will it work with an MPEG2 source file? Does the filter work pre or post compression in VDub? I tried up to 4 sequential loads of the deblocking filter in VDub and could not see any change in blockiness of a low bitrate MPEG2 file.
    Thanks.
  14. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Very unstable under both VirtualDub and VirtualDubMod. I was getting crashes when trying to launch the preview window. Every time I hit preview, VirtualDub bombed.
    Read my blog here.
