Can somebody help.
When i download and install Sp2 for Windows Xp after the install im unable to get on the net.
Has anybody come across this problem?.
Has anybody got a solution?.
Thanks in advance.
Results 1 to 13 of 13
SP2 turns firewall ON by default.
check your firewall settings.
i couldn't access the net using firefox browser until i had to allow it access through the firewall settings. -
It could also be a spyware problem.eliminate spyware before installing sp2
I have been trying to restore my computer to an earlier point, but each time I try it indicate there's no change. This is a well known problem with SP2
anyone know if there's a fix for this problem ? I am running a DELL 8400
Tks..
FFL
You are in breach of the forum rules and are being issued with a formal warning. Hijacking a topic is not acceptable. You did it twice. Please start your own thread if you have a question.
/ Moderator offline -
What date are you trying to restore to and do you have Norton installed?
Sometimes Norton can interfere with system restore. -
I am trying to restore to the first date i set up my computer, I do not have norton, but i have mc afee, ( I did not disable the antivirus or firewall I will try that tonight) I tried in safe mode, but no dice.
Thanks and Regards
FFL -
What date would that be.Originally Posted by ForeighFilmlover
The restore points only go back a month. -
I've got restore points from about 6 months ago. It all depends on how much drive space you allocate to system restore.
I am trying to restore to October 04, in the manual and other documents that came with the computer, DELL brag about being able to restore to the first day of set up.
Thanks and Regards
FFL -
OH by the way,
another tech question ! at home i can enter other forums, and reply and post questions, except this forum, I can sign in, read the post move around to any area of the forum, but I cannot reply to ANY post. when I hit the reply button I get a blank screen. it does not happen in any of the other 5 forums I view. any suggestionsThanks and Regards
FFL -
Did you select a time on that day?Originally Posted by ForeighFilmlover
Is QT Alternative 1.81 and 3.x compatable with Windows Vista SP2?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 8th Feb 2010, 00:02 -
Windows XP x64 SP2 doesn't recognize DV Camera. Other OS does (ex: Linux)
By alkalinelito in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 4th May 2009, 23:03 -
Windows XP SP2 capturing problem
By superdud1400 in forum Capturing and VCRReplies: 4Last Post: 23rd Jun 2008, 00:50 -
Auto play problem in WinXP SP2
By bevills1 in forum ComputerReplies: 4Last Post: 3rd Mar 2008, 11:09 -
Problem installing Sony HDR-SR1 on XP.SP2
By erik010 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 1st Jul 2007, 06:40
