I've got an AVI ripped from DVD that contains two audio tracks. One is the main track and the second one is the commentary track from the DVD.
Is there a way to convert this to VCD or SVCD that will preserve the secondary commentary track so I can switch to it while watching it on my DVD player? Or do VCDs and SVCDs only support single audio tracks?
I dropped the AVI onto ffmpegX but the new interface doesn't allow me to read all the audio information. The info for the second track is cut off:
mp3, 48000 Hz, stereo, 116 kb/s
Stream #0.2:
Originally Posted by major
**ERROR: [mplex] Too many frame drops -exiting
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 3004344
INFO: [mplex] target data-rate specified : 2788800
++ WARN: [mplex] Target data rate lower than computed requirement!
++ WARN: [mplex] N.b. a 20% or so discrepancy in variable bit-rate
++ WARN: [mplex] streams is common and harmless provided no time-outs will occur
INFO: [mplex] Run-in Sectors = 79 Video delay = 47400 Audio delay = 51000
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 235520 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Audio c1: buf= 4096 frame=000000 sector=00000000
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=2726400 required(DTS)=2726400
++ WARN: [mplex] Video e0: buf= 210224 frame=000745 sector=00003783
++ WARN: [mplex] Audio c0: buf= 3016 frame=001139 sector=00000363
++ WARN: [mplex] Audio c1: buf= 3259 frame=001240 sector=00000363
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=2906400 required(DTS)=2899200
++ WARN: [mplex] Video e0: buf= 233219 frame=000792 sector=00004035
++ WARN: [mplex] Audio c0: buf= 4096 frame=001214 sector=00000387
++ WARN: [mplex] Audio c1: buf= 3931 frame=001322 sector=00000387
++ WARN: [mplex] Stream c1: data will arrive too late sent(SCR)=3086400 required(DTS)=3069120
++ WARN: [mplex] Video e0: buf= 235520 frame=000840 sector=00004289
++ WARN: [mplex] Audio c0: buf= 4096 frame=001287 sector=00000410
++ WARN: [mplex] Audio c1: buf= 1800 frame=001400 sector=00000410
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3266400 required(DTS)=3244800
++ WARN: [mplex] Video e0: buf= 233219 frame=000888 sector=00004543
++ WARN: [mplex] Audio c0: buf= 4096 frame=001359 sector=00000433
++ WARN: [mplex] Audio c1: buf= 4096 frame=001479 sector=00000433
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3446400 required(DTS)=3417600
++ WARN: [mplex] Video e0: buf= 233219 frame=000936 sector=00004795
++ WARN: [mplex] Audio c0: buf= 4096 frame=001434 sector=00000457
++ WARN: [mplex] Audio c1: buf= 4096 frame=001561 sector=00000457
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3626400 required(DTS)=3586800
++ WARN: [mplex] Video e0: buf= 233219 frame=000983 sector=00005049
++ WARN: [mplex] Audio c0: buf= 4096 frame=001506 sector=00000480
++ WARN: [mplex] Audio c1: buf= 4096 frame=001639 sector=00000480
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3806400 required(DTS)=3756000
++ WARN: [mplex] Video e0: buf= 233219 frame=001030 sector=00005304
++ WARN: [mplex] Audio c0: buf= 4096 frame=001578 sector=00000503
++ WARN: [mplex] Audio c1: buf= 4096 frame=001715 sector=00000502
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=3986400 required(DTS)=3925200
++ WARN: [mplex] Video e0: buf= 233219 frame=001077 sector=00005558
++ WARN: [mplex] Audio c0: buf= 4096 frame=001648 sector=00000525
++ WARN: [mplex] Audio c1: buf= 4096 frame=001797 sector=00000526
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=4166400 required(DTS)=4108800
++ WARN: [mplex] Video e0: buf= 233219 frame=001128 sector=00005809
++ WARN: [mplex] Audio c0: buf= 4096 frame=001726 sector=00000550
++ WARN: [mplex] Audio c1: buf= 4096 frame=001879 sector=00000550
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=4346400 required(DTS)=4281600
++ WARN: [mplex] Video e0: buf= 233219 frame=001176 sector=00006061
++ WARN: [mplex] Audio c0: buf= 4096 frame=001801 sector=00000574
++ WARN: [mplex] Audio c1: buf= 4096 frame=001961 sector=00000574
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=4526400 required(DTS)=4450800
++ WARN: [mplex] Video e0: buf= 233219 frame=001223 sector=00006315
++ WARN: [mplex] Audio c0: buf= 4096 frame=001874 sector=00000597
++ WARN: [mplex] Audio c1: buf= 4096 frame=002039 sector=00000597
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
question how to add audio track to avi
By jimdagys in forum Video ConversionReplies: 6Last Post: 24th Dec 2008, 06:07 -
Commentary track
By AlanHK in forum AudioReplies: 10Last Post: 6th Nov 2008, 02:47 -
How to remove commentary track in AVI.NET?
By sads in forum DVD RippingReplies: 0Last Post: 23rd Oct 2008, 10:47 -
Add a commentary track to A DVD
By R3bel in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 08:42
