how do i create a que for overnight encoding for more than 1 movie with this great app?
cheers?
Results 1 to 9 of 9
Just add one file (movie clip) after other.
But they would be encoded as 1 DVD with different VOB's. -
first of all thanks for answering but i would like them seperated, so i can burn each movie onto a seperate dvd
cheers -
It doesn't have that option.
It barely has ANY options, but it does very well what it's supposed to do - DivX to DVD. -
can't you just start several divxtodvd and encode all at the same time? slow but if you do it over the night it wont matter
Damn. Wouldn't think of it.
Baldrick, you're right (like always).
Thanks. -
no need for baldricks step.
just select the first source file,then pick another,then another till you have what you need,pick the destination,sit back and itll encode with multiple titles.
only one divxtodvd running! easy.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
avinitski wanted several dvds not one dvd with multiple titles...or does it split to multiple dvds?
it splits to mulitple titles,not had the time or patience to try that yet.
he could split them with shrink,as the quality of 2 or 3 movies on one dvd is quite good.buti just got a new capture card to play with and nothing to capture and convert..damn superbowl.
just checked,they inform me a queue will be in a later version,possibly the full one,whenever that appears.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
Something wrong with DivxToDVD download here?
By gastrof in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2011, 10:46 -
VSO Blu-ray to DVD
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2011, 12:40 -
Slower encoding with VSO than it used to be
By Brainstorming in forum Video ConversionReplies: 8Last Post: 28th Dec 2010, 20:52 -
pc crashes with vso convertx
By dvdex in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2009, 18:40 -
divxtodvd problem
By BPH2002 in forum Newbie / General discussionsReplies: 31Last Post: 27th Jun 2007, 08:17
