Hi
I have the following problem
every time I'm importing a dvd, it splits into different titles even if I created a dvd with only one chapter !
How can I import a dvd being 1 single video ?
Thank you
You have to rip it as one video file. By Different titles you mean one Movie in many different Tittles? This is a DVD with one movie/Title right? If thats the case then yes rip into one File before you bring it into Workshop.
OK I have the same problem.
I made sure the titles I was importing (edited in DVD MovieFactory 3) were only 1 chapter, but when I import them, I get like 3 or 4 Titles.
What do you mean rip it into 1 file before importing? -
He means, when you rip your movie, have it so that it does not break up the film in 1 gig files, have it so it makes one giant 4 (or whatever) gig file. If your disc is something you had made on the pc, then you would need an editor or something along those lines that can take your vob files and merge them together as one big file.
one good editor is womble mpeg2vcr
and i know their used to be an app called vobmerge, but im not sure if it is still on this site?
once you make your file use the regular import media option and not the import dvd option
Ulead is very screwy when you use the dvd import option and .. well you know the results of that -
Thanks, I actually played with Decrypter after I posted my reply.
And In Decrypter I chose (under File mode) "NO SPLITTING".
It worked.
IMporting to Subtitle Workshop from txt file
By kouim in forum SubtitleReplies: 4Last Post: 27th Jan 2011, 16:26 -
Importing timing into Subtitle Workshop
By yonyz in forum SubtitleReplies: 2Last Post: 9th Feb 2009, 11:04 -
importing a DVD into VEGAS Studio
By lissow in forum Newbie / General discussionsReplies: 1Last Post: 3rd Aug 2008, 01:34 -
DVD WORKSHOP 2 problem playing subtitles
By Bella in forum Newbie / General discussionsReplies: 8Last Post: 2nd Jun 2008, 11:17 -
DVD Workshop 2 audio problem
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 21st Feb 2008, 19:49
