When using Tmpg's DVD author 1.6 I'm having a strange problem. I select the mpeg2 files I want to convert. I'm using one track and putting 2 clips in that track. It accepts the files with no problems when I open them. I then make the menu for the DVD. But when I click "begin output" the program just vanishes from my screen. No error message, nothing. Then I'm left with and empty Audio_TS and Video_TS folder in the place where I chose to save the output. Any idea why?
No it's not lazy, thanks for taking the problem seriously, and reinstallation does nothing. Does anyone with knowledge have any actual technical help?
does it quit with all mpeg2 files? tried just one mpeg2 file or other mpeg2 files? how did you create mpeg2 files?
It does it with Mpeg2 files and Mpeg1 files as well. So far, whatever I use in it, it crashes when I try the "begin output" phase of the process. Tmpg 2.5 was used to create the mpegs, they were converted from avi's. Again, no error messages or anything. Program just disappears.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
TMPGEnc DVD Author 3
By WHISPERS1944 in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2008, 04:56 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
Have you tried reinstalling it?
