Closed Thread
  1. On transcoding an audio file from 44.1Khz to 48Khz. An error displays
    One of the files is no longer present...
    c:\Films\Meet the fockers\fockers_svcd1_48k.ac3
    Do you want to locate file manually?
    Yes or No
    Strange, as this is the output file!!!
    I have unistalled DVDLAB pro and then reinstalled but still the same message.
    Version 3.0.0.153
    PRO 1.0 build 041014
    Anybody had similar problem? Driving me crazy!!
    Help please.
    You are in breach of the forum rules and are being issued with a formal warning. No Warez. This is not set to be released until April.
    / Moderator Capmaster
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If you're transcoding the audio to 48KHz and using DVD-LAB, I'd assume that you're trying to make a DVD, and I'd suggest that instead of going from DVD -> SVCD -> DVD that you make a straight DVD backup - it'll be much quicker and much less hassle and much better quality
    If in doubt, Google it.
  3. Demux the file beforehand, and transcode audio to AC3 in ffmpeggui. Import the AC3 as the audio for your movie into dvdlab.
    Cheers, Jim
    My DVDLab Guides
  4. Originally Posted by carpy666
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
