Hi
This is my workflow converting DVD to VCD. First I copy the DVD to the hard disk using DVDDecrupter. Than using DVD Author I’m extracting the main title back to mpeg2 and burn it as VCD compliant.
Now I want to include subtitle from the original DVD files. Any idea?
S
Just me or you left out a step or two? Such as converting the mpeg2 to VCD compliant MPEG1 and authoring before burning.
No. The sub has to be added into the video.
Unless I missed something, subs cannot be turned on/off on VCD.Want my help? Ask here! (not via PM!)
no..but i was thinking about application like YASHA DVD to VCD that does it for you. the only reason i dont use it becuse its extremly slow.
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 13:31 -
Need help adding a subtitle to a DVD.
By chris4556 in forum Newbie / General discussionsReplies: 7Last Post: 24th May 2011, 21:12 -
adding watermark as a subtitle
By zammil in forum SubtitleReplies: 8Last Post: 20th Nov 2010, 00:45 -
adding subtitle
By Rezadarius in forum ffmpegX general discussionReplies: 1Last Post: 9th Aug 2008, 04:45 -
Adding a subtitle for a DVDR
By rotchild in forum SubtitleReplies: 5Last Post: 28th Jan 2008, 11:07
