Can anybody tell me hot to demux avi files to video and audio streams.
Suppose the avi file is a divx/Xvid file with AC3 5.1 audio. Then how to extract is AC3 audio from it in the same format. ffmpeg converts to 2 channel format. I want to retain all the channels.
Thanx in advance
open the file in virtualdubmod, and you can save the audio from the streams list.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
yep, Forum Troll is spot on. Open your file in virtualdubmod, then go to streams . stream list, and click the demux button. This should save the AC3 out to its own file. Then you can just feed the AVI into your encoder, encode either video only or as elementary streams and just discard the audio it outputs, then use your authoring software to join the two back together.
If you truly want a video-only AVI, after you have demuxed the audio out to AC3, simply click the disable button in streams > stream list, then go to video > Direct stream copy, then File > Save as ... and save out a new audio-less AVI.If in doubt, Google it.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 08:21 -
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 16:24 -
How to Create FLV files from AVI material ( Xvid / Divx )?
By devilcoelhodog in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2010, 10:31 -
Extract Audio from XviD MPEG-4 video
By MI6 in forum AudioReplies: 2Last Post: 3rd Jan 2009, 06:58 -
Help with re-encoding avi files (XviD/DivX)
By noskid21 in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2007, 15:24
