  1. I've spent the last couple of days searching, waiting for this opportunity to ask my question. I did find lost's of usefull info, but nothing to help me with my problem.
    Have made several successful re-author discs using Dolby Digital clips, but when I try to do DTS scenes I get the audio out of sync. Out of 24clips about a 1/3 are out of sync. I'm guessing that it has something to due with the demultiplexing. I'm not sure what I'm doing wrong, since each time I try to complie scenes different clips have the audio problem, it's not the same clip each time.
    When I compile the DTS scenes using DVDshrink there are no sync issues.
    Attached is the demultiplexing properties, in case I didn't select the right option.
    Hope I put this the right forum, the problem is with audio but it's when I re-author it becomes an issue.
  2. Do you let DVDLab Pro demultiplex your stream? There was a problem in the past with the demultiplexor of DVDLab. Try demultiplexing in an external app, then bring the two streams into DVDLab Pro. See if that helps you out.
    Mark
  3. Thanks Mark!
    Do you have any recommendations for a particular prgram?
  4. TMPGenc can demultiplex for you.
    Mark
