I have extracted a dat file from the *.bin file and then used vcdgear to convert that to mpeg, as per this link:
http://www.doom9.org/index.html?/mpg/vcd2divx.htm
Now, when I open up Virtualdub and load the *.mpeg file, I get this error message:
MPEG Anachronistic or discontinuous timestamp found in video stream 0 byte position 2340 (may indicate improper join)
MPEG Anachronistic or discontinuous timestamp found in video stream 0 byte position 4664 (may indicate improper join)
Then after selecting 'Full processing mode' and 'Compression' I don't see the 128Kbit/s audio bitrate from the 'MPEG Layer 3' selection.
I have downloaded and installed the DivX 3 codec, but still no 128kbit/s audio.
Bob Heselwood
Thanks, that did it for me; showing all available audio bitrates now including 128Kbits/s
Bob Heselwood
FFmpeg Audio Codecs
By Klagar in forum AudioReplies: 10Last Post: 11th Nov 2010, 11:15 -
Whats the best audio codecs to have
By adamf154 in forum AudioReplies: 4Last Post: 7th Apr 2010, 17:31 -
audio codecs problem...
By cwb in forum LinuxReplies: 1Last Post: 13th Jan 2008, 15:12 -
multiple audio codecs?
By cwb in forum Newbie / General discussionsReplies: 0Last Post: 12th Jan 2008, 21:24 -
New / problem with codecs
By AJ Martinez in forum Newbie / General discussionsReplies: 8Last Post: 14th Oct 2007, 19:32
