Results 1 to 12 of 12
  1. Hi all:
    I´m trying to make a dvd back up of a dvdv-r and after I open dvd decrypter this message shwed up:
    Message= Access violation at address 004FA395 in module "dvd decrypter.exe" write of adress 00001E00
    What should I do???
    Please do not post twice. Your other post has been locked
    Moderator Offline
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    uninstall dvd decrypter then reinstall it
    Don't keep posting the same problem. Post it only once. You have another thread with the same problem.
  3. ok I will do it , but i do not understand, after that message I did decrypt sever others dvd- r with no problem...
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    what brand is the dvd-r?
  5. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    the disc may have a scratch or a smudge on it so it can't be read.
  6. It is a Ritek 8X...I never had a problem with them...
  7. I hit "OK" after that message appears an this came up..
    Acces violation at address 0057E066
    in modle "DVD DECRYPTER.exe Read of address 0000C674
  8. After I hit ok again and again after the 3rd time this showed ip...
    "INVALID POINTER OPERATION"
  9. I'd say the course of action to take at this point is to say screw it . You said it isn't having problems ripping other discs, just rip it with DVD Shrink or something else then and move on.
  10. ok... Thank´s Steve 2713 ..i´m not familiar with ripping with dvd shrink and copying whith it but I will try!!!
  11. It's simple to rip with it DVD Shrink. If you want to burn the copy with DVD Decrypter, just be sure to rip the disc as an ISO image with Shrink(the option comes up just before it rips the disc), then burn the ISO with Decrypter.
  12. There is another tool on the block called "smart ripper". Though it is less polular than DVD Decrypter bu still is does a good job. Try it.
