Hey i had some prior problems convertin a DIVX > MPEG 1 ( didn't know it was divx at the time... )
Now i figured out how to make it an AVI so i can successfully convert it to mpeg1...
Now i need to know hwo to make the file convert to AVI small enough.. (2 minutes into the movie and the files 3 gigabytes.)
Any feedback or ideas is greatly appreciated. thank you.
Use compression with a codec like huffyuv or picvideo. Also, what resolution is your file and what resolution are you converting to? It sounds like you are using something a lot larger than VCD resolution. If you are, and you are going to VCD, then you could lower your resolution to 352x240 (NTSC) and save a lot of space. Check out some of the guides on the left.
VirtualDub question on huge file sizes, and save to formats
By etbrown4 in forum Newbie / General discussionsReplies: 10Last Post: 30th Sep 2011, 05:27 -
I need to edit a huge .avi file
By Hobittual in forum EditingReplies: 2Last Post: 25th May 2010, 16:40 -
WMV to Avi(xvid,mp3) using VirtualDub - huge destination file
By chm in forum Newbie / General discussionsReplies: 9Last Post: 20th May 2010, 18:29 -
Making XVID videos with VirtualDub: output files w/huge file sizes (~1GB+)
By maskingtape in forum Newbie / General discussionsReplies: 11Last Post: 5th Mar 2010, 00:50 -
2 Small-ish AVI -> 1 Larger AVI = HUGE File. Why?
By cxp36 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 18:31
