  1. I have a standalone DVD burner that I burned a bunch of home movies with. I would love to rip a few select titles from the various DVDRs and compile them on another DVDR and add a menu.
    I would probably rip them using DVD Shrink, but is there a way to add a menu with those ripped data files? I want to make sure I don't end up re-encoding the files or re-compressing them. All the chapter markers are in the titles as well and I would like to keep those if possible.
    I may be asking the impossible, but I'm hoping someone will know here either way. I have DVD Architect by Sony but I haven't had a chance to learn much about it yet... perhaps that would do the trick somehow?
    Thanks for your help!
    -DVD-Dude
    tmpgenc dvd author, add dvd video and you can select titles. you can also use ulead dvd workshop or ulead dvd moviefactory and import dvd-video.
    or convert to video and audio streams and import in dvd architect. https://www.videohelp.com/guides.php?guideid=638&howtoselect=4;14#638
