I made some DVDs by using TMPGEnc to convert AVI to MPEG2 and using Nero to burn MPEG2 into DVD disk, and it works.
I saw lots of authoring in DVD making, can anyboby explain the significance of DVD authoring? Thanks a lot.
Mike
Results 1 to 9 of 9
did you just burn the mpeg2 on a dvd? or did you use nerovision express?
authoring makes the dvd-video file structure, vob,ifo,bup files and also optional menus, chapters etc. -
DVD authoring is about making correct chapter points, menus etc (everything little extra to give a little more professional feeling of your crappy home video / TV capture / whatever) ... Of course DVD authoring is also making your files DVD compliant, so they work on every DVD player, not just on some "made in china model XYZ"
What I did was to convert AVI into MPEG2 using TMPGEnc, then open the nerovision express, drag the MPEG2 files into it, next, next, ..., a DVD is born.
So, what is authoring in DVD making? Thanks for your explaination.
Mike -
nerovision express author your mpeg2 to a dvd-video.
authoring makes the dvd-video file structure, vob,ifo,bup files and also optional menus, chapters etc. see above. -
Thank you all for your explaination.
Now I think I understand about DVD authoring, it is putting the mpeg2 files into a special file structure that DVD players can recognize.
Some softwares do the authoring work behind the scene.
Mike -
Yes but if you can also equate it to making a book....Originally Posted by MikeZ2
First Play Video=The cover
Menu=Table of Contents
Chapters=Chapters etc...
Which is probably where the authoring name comes from. -
can nero be used to author SVCD to dvd then as tmpgenc DVD author always says video ratio cannot be used with DVD.
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 22:51
