I think I'm missing something here. I have a divx movie on my hard drive,.. and I went to convert it using TMPGENC,.. but I think it's too big.
I get an error message that says file might not fit on your media.. do you want to continue??
The movie is less than an hour and a half. Is this possible??
Is there a way to shrink it??? Do I ignore the error message??
Sorry for all the newb questons.
try convert the audio to wav
www.videohelp.com/tmpgenc#problems , tmpgenc may get the runtime incorrect if it is mp3 vbr audio. -
I am assuming you mean bitrate. It's calculations are spot on (although bitrate calculations aren't rocket science), however sometimes it just can't match them. I have one movie 102 mins long (a family holiday when the camera was new). It gives me a calculated rate of around 5770, which is correct, yet on three attempts has produce a movie with an average bitrate of 1700-1800. This is despite reindexing and checking the original for errors. Audio sync is good, and the image isn't bad, just softer than it need be. It does process this file in about 75 minutes, which is much faster than any other encoder I have used. The couple of others I have done have all used the calculated space.
Read my blog here.
Was more refering to keeping max bitrate in check, etc. so as to avoid VBV underflows.
Sometimes I get this error when converting an XVID source to MPEG-2. TMPGEnc thinks the source video is much longer than it actually is. I think this happens (at least for me) beacuse my source is of variable bit rate.
To fix this, I just use TMPGEnc's source range settings, and set the last frame as the end frame (instead of the default of -1). This produces much more realistic bit rate values.
I'm not sure what's the deal with TMPGEnc's bit rate calculation, but this has method has solved the problem for me everytime.Go All Blacks!
DVD to DivX Conversion - Recommended File Sizes
By DakotaThrice in forum Video ConversionReplies: 3Last Post: 13th Jun 2010, 08:31 -
File conversion problems AVI to Divx
By kaptainm in forum ffmpegX general discussionReplies: 2Last Post: 10th Aug 2008, 20:21 -
Big blocks on XVid to MPEG conversion
By hewsongs in forum Video ConversionReplies: 7Last Post: 30th Mar 2008, 16:50 -
DivX to Mpeg -> DVD Conversion is Jerky
By jedijfo in forum Video ConversionReplies: 4Last Post: 15th Oct 2007, 09:32 -
conversion file to big
By jimk16 in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2007, 05:05
