hi
is there any way to edit video files especially mpeg 1 & 2
without re-encode?
if you know a written guide or post just let me know.
thanks
https://www.videohelp.com/tools?s=107#107
my favorites are videoredo, cuttermaran, tmpgenc. -
i just posted an app that I wrote for myself. You select start and end points for the video you want to extract, and click "go". No re-encoding, it just splits up the file. It works great for the MPG1 and MPG2 files that I capture. Works only for CBR (constant bitrate) encoded files. Have not tested on AVI files, but if they're CBR it should work. Give it a try.Originally Posted by ss-reich
http://www.geocities.com/vidsplit -
hi there.
yep, TMPGEnc mpeg editor is a brilliant mpeg editor and wont re-encode your file to mpeg again, it simply renderes the frame each side of the edited or cut section, and thats it, takes a few seconda to do and done, great tool.
be careful when u use the term "edit" i get chastised for calling tmpgenc 3.0 an editor and encoder (dumb) because its suposedly not an editor, it just cuts, splits, joins etc, but if its not an editor, what is it, a cutter, a splitter, a joiner, hell im confused, cos according to some, editing is when u do all the stuff the authoring program is able to do, hence the use of sony vegas to edit, then encode, but it seems that the editor in vegas is very much just like a very good quality authoring tool, just saves one from adding all the fancy stuff when authoring, and i dont want my dvd mpeg file sitting on my pc with all the works added already, i want to add that stuff while authoring.
anyway, thought id mention it anyway.
have a nice day....GLEN -
Womble MPEG Video Wizard or MPEG-VCR... frame accurate cutting and joining with no re-encoding.
Freeware that can do I and P frame cutting and joining: Cuttermaran and MPEG2Schnitt
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Jan 2011, 23:35 -
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 05:08 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 13:13 -
Help encode permanent subtitles and then edit DVD
By kapital in forum Newbie / General discussionsReplies: 11Last Post: 29th Apr 2008, 09:43
