    Jul 2001
    I have a DVD that I'd like to copy but on the copy I want to add a folder containing pictures. I don't need the pictures to show in a slide show on the tv. I only need them on the DVD so that I can acces them from the PC as a data folder.
    How do I go about copying the original DVD and add this folder.
    Thanks for any help
    BM
  2. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    I've done it with nero.
    Have the VIDEO_TS folder on your HDD,
    With the dvd files in the VIDEO folder of course,
    then i have just put the jpg images i wanted into the AUDIO_TS folder and burned with Nero Burnin Rom. Just add the contents out of the VIDEO_TS folder on your HDD to the VIDEO_TS folder in NBR and do the same for your images into the AUDIO_TS folder. Burn.
    copy the dvd video_ts folder to your hd. use dvddecrypter if it is encrypted or shrink it with dvdshrink if it wont fit a dvd-r.
    select new dvd-video in nero burning rom, add the video_ts. make a new folder for the images. burn. do NOT put any files in the AUDIO_TS and VIDEO_TS folder.
  4. Banned
    Jun 2004
    Why Not ?? I have done several that way and they all play fine on standalone players. But when i have done it there was nothing else in the AUDIO_TS folder.....
    Dec 2004
    LOST
    That extra folder will be burned and accessible with Windows Explorer? If that's the case, it means I can mix DVD files (VOBs) and MPEGs, JPEGs and AVI's with the possibility of playing them in my DVP642.
    May 2003
    Iceland
    Baldrick is very correct I also have been backing up my avi's and pics this way
    AUDIO_TS folder
    Backups or Pics folder
    VIDEO_TS folder
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    You may get problems with dvd audio players...probably not...but why not create a new folder instead of hiding them in the audio_ts folder .
