Results 1 to 15 of 15
    Jan 2005
    Hello everybody, first time poster, i'm getting married in June and looking for a photographer but when i do find 1 they usually put the pics on cd for you to view them copyrighted obviously but how would i be able to copy the disc myself just so i can let people iin family have 1 to remember the day, photographers don't come cheap neither for this kind of venue can someone please help me out, your help is greatly appreciated.
  2. Member mikesbytes's Avatar
    Sydney, Australia
    Hi Boldy and welcome.
    Its sounds as simple as using a disk copy program, but tell us a bit more about what you want to do? Do you want exact copys of what the photographer gave you? Do you want to get the photos off the disk and use them differently?
    The first step is finding out what kind of disk you have, is it a vcd, a kodac picture disk?, is it a DVD. Try opening your disk with windows explorer and report back what files and folders you find in the root directory.
    Have a nice Day
  3. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Most likely you can just copy the images from CD to HD. Be aware those images can be digitally watermarked and digitally tagged as copyrighted. I'd look around for a photographer that will waive the copyright, most will for an additional price. At least that's what there starting to do in my neck of the woods.
    Jan 2005
    thank you both for your replys won't they usually put them as jpeg pics if so how do i copy the full disc, if it 's a vcd slideshow then all i gotta do is rip the mpeg from the .dat file is that correct, i would like the pics as they would be on the disc.
  5. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    If there in jpeg format just copy and paste, if it's in VCD format they are going to be of such a low quality it's not going to be worth the effort. Even screencaps from full size DVD compliant mpeg's are relatively low resolution pictures.
  6. Hi boldy,
    Normally the CDs created by the photographers / studio peolpe are ordinary data CD with 2/3 folders on the disk. There is a small software on the disk whihc will play the files as a slideshow when you insert the CD. One CD may contain images from more than one film. One of the folders on the disk actually contain the images in jpeg format. You can simply copy the files to your hard disk using windows explorer.
    To make an exact copy of the disk use the "copy disk" option of the burning software you are using. Use Nero Burning ROM if presently you dont have any.
    Jan 2005
    i thought that the copy disc in nero only copied music didn't know about pics.
  8. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    You don't need to copy disc, just pop it in your drive, and eplore it in my computer. Find the files, select them, selct copy then paste them somewhere on your HD. That is if they are image files such as JPG's.
    Jan 2005
    could you give me a breif on what other formats they could be in, also what if they are in kodak cd how do i copy that, just have a lot of family and would like to give them a copy of the disk as a reinder of our big day.
  10. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    <sigh> There's anyone of many formats they *could" be in. Just look around the disk, use thumbnail as the view.
  11. Member mikesbytes's Avatar
    Sydney, Australia
    Body, could you open the disk in mycomputer (usually in the top left corner of the screen) and tell us what files and folders you see.
    Have a nice Day
  12. boldy,
    The "copy disk" option can be used to copy any disk. be data, audio or video. It doesnt matter. So in your case if you want to distribute the disk as it is then you can simply use the "disk copy" option to make as many copies as you like and distribute to your friends and relatives.
    However if you want to copy the images stored on your CD to your hard disk. You can do so very easily using Windows Explorer. The stored images on your hard disk can be easily viewed by double clicking on them. A very good image viewer is "Irfanview".
  13. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    You can view thumbnails in XP folders by selecting view>thumbnails from the file bar at the top. If you want to make it a slideshow folder select View>customize this folder>.... Select photo album from the first drop down box and click apply.
    Jan 2005
    would this be the samefor taking pictures with a digital camera would i open the file where pics are and then right click and send them to the cd burner and that will create a pic cd, is this correct, thank you in advance.
  15. boldy,
    You can use the WinXP built-in feature for writing files to a CD. The disk created will be a plane and simple data disk with all your pictures. However, it will not be same as a "Kodak Photo CD" OR like any other "Picture CD" created at the studios. The diff is not much. Kodak CDs or similar Picture CD are also data disks PLUS some additional software to view the pictures stored on the disk. When you inset such a disk in your drive the s/w will automatically start and show your pictures as a slide show. (as I had mentioned earlier in ths post).
    The CD created with WinXP CD writing feature will not "Auto Run" in this fashion.
