Hello everybody,
A long time since I posted a message, everything went OK with my encodings until I came accross this issue.
I made a lot of DVD's for my own footage, encoded it with Tmpg or CCE then used Ulead DVD moviefactory for the authoring.
On some DVD's, at random locations in the movie, playback is momentarily interrupted : screen goes black, then a blink of an eye later, it resumes. Random because it occurs at different places in different movies but in the same movie systematically at the same place. I even tried different media, +R, -R, +RW, -RW, different brands but that didn't change anything.
This issue does not occur on my JVC player but since I largely distribute my productions, it occurs on almost every other player : philips, panasonic, sony...
Did one of you come across this issue too ? and how to overcome it ?
thanks a lot in advance
jacobus serpenti
Be yourself and be happy in what you do
How do you Author. Do you use multiple clips and let the authoring package join them together, or do you have one large movie?
There are 10 kinds of people in this world. Those that understand binary... -
Hello Bugster,
Thanks for your reply.
I author several different clips, one that autoruns when the disc is inserted, then a menu screen appears with 6 differents short clips to run (length from 4 to 15 minutes) from. When one clip is finished the menu returns.
The bug occurs in one of these 6 clips, always at the same place in the clip. Note that I viewed the mpeg2 file on my pc and it plays flawlessly without any bug (so I excluded the encoding being the source of the bug).
I guess also that it has nothing to do with the media nor with the brands. Maybe it is just an authoring bug?
Best regards
jacky serpentiBe yourself and be happy in what you do -
It could be a media bug, or it could be a video bug, or it could be an audio bug.
Just because it plays on the computer, does NOT guarantee it will play in your standalone.Cheers, Jim
My DVDLab Guides -
Originally Posted by Jacobus Serpenti
The problem isn't near an edit point by any chance?There are 10 kinds of people in this world. Those that understand binary... -
always at the same place in the clipCheers, Jim
My DVDLab Guides -
Hello,
As a matter of fact, the point in question is where I inserted a static image just after some regular video footage. It could be that my editing software (Canopus EZDV) didn't handle correctly this passage.
I'll try to modify this somehow
Anyway thanks for the hint
Jerky playback
By hi2shy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 30th Nov 2010, 16:44 -
Jerky Playback
By electrowiz in forum Video ConversionReplies: 1Last Post: 25th Aug 2010, 16:16 -
DVD Backup - erroneous playback on dvd player althought perfect on the pc
By RedBolt in forum Authoring (DVD)Replies: 3Last Post: 11th Jun 2010, 23:00 -
jerky playback
By VOYAGER2009 in forum Video ConversionReplies: 19Last Post: 22nd Feb 2010, 05:27 -
Jerky playback on TV from PC using TV Out
By digidude in forum Software PlayingReplies: 0Last Post: 30th Dec 2008, 17:26
