Hello,
I hope this is not another stupid question. I take photos at a resolution of 1600x1200 (4:3 aspect ratio) and I would like to view them fullscreen, without any deformation nor distortion, on a 16:9 wide screen TV.
I've tried several combinations a resizing, cropping, stretching, squeezing to no avail : a circle eventually looks like an oval or the photo doesn't fill in the entire screen (which is absurd!)
I'm using ulead dvd moviefactory for building the photo slideshow, but it doesn't include any resizing tool, so manipulating every single photo (out of a collection of several hundreds) is too cumbersome.
So the final questions : how to do the resizing for a viewing on a 16:9 screen ? Is there a tool that automatizes this ?
thanks a lot
jacky serpenti
Be yourself and be happy in what you do
Originally Posted by Jacobus Serpenti
/Mats -
Hello Mats
Thanks for the advice, by cropping you mean actually removing a part of the photo to have it fit into a 16:9 ratio box (1600x900) ?
If so, do you know of a program doing that on batches of photos (several hundreds at a time) ?
Best regards
jackyBe yourself and be happy in what you do -
I do this with Paint Shop Pro 9. It has batch prosses utility. Also you can record your own script and aply it to several hundreds pictures at once.
This is how I do it.
1. I open one picture to work with.
2. I click Record Script button.
3. Resize pictutre from 1600x1200 (4x3) to 854x640 (4x3) at 100 dpi.
4. Resize canvas (crop) from 854x640 (4x3) to 854x480 (16x9) at the same 100 dpi.
5. Click Save Script button and save my custom script with some name.
6. Start Batch Proccess dialog, select all your pictures, select your custom script and click Start button.
Works great.
But this is for NTSC TV wich has aspect ratio 1.33 with frame size of 720x480 for 4x3 TV and 1.78 aspect ratio with frame size of 854x480 for 16x9 TV.
As far as I know PAL TV 4x3 frame size is 720x576 with aspect ratio 1:25. 16x9 frame size would be 854x576 with aspect ratio of 1:48. You need to double check.
Regards. -
Nope, no idea, I'm afraid. But wouldn't you like to determine which 1600*900 part of the 1600*1200 you'd like to keep for each image? I mean, on one pic, there's lots of blue sky that you can live without, while on another, there might be a vast stretch of water in the lower half, but that rare seagull near the top edge is what the pic is all about.
/Mats
Going from high resolution photos to low resolution photos
By bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2018, 11:57 -
Viewing and storing photos/video on CD/DVD
By Mellie in forum ComputerReplies: 9Last Post: 8th Jan 2010, 13:24 -
Photos off DVD video made of photos?
By 5chandlers in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2009, 12:31 -
Viewing Photos On A DVD On TV
By joedough in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2009, 10:37 -
Can''t see photos
By Kase in forum Newbie / General discussionsReplies: 1Last Post: 19th May 2007, 23:05
