Ive noticed that DVD shrink is slowing down again, I t happened before and I ended up restoring my pc and after that it went faster again. Now I noticed that its going slow again when i use it and I think after shrinking so many movies, eventually it will slow down. So what I did was I put a movie that I have shrink before(already deleted old movie files) and did not analyze dvd anymore, it already went to the main screen where u see all the menus and stuffs. So I think somehow when u shrink a movie , some info will be in ur pc memory, unless u do a system restore,Anybody knows where to look for that, I dont think that its in the dvd shrink folder cause I tried reinstalling already, didnt work, so from 30minutes now it takes more than 1 hour.
Results 1 to 11 of 11
I've noticed mine is awfully slow recently too.
My version is 3.2.0.15 -
DVDShrink saves the results of the initial analysis of a disc as well as the deep analysis results on your hard drive - do a forum search for "DVDShrink Documents Settings" and you'll be able to find the exact path. IMHO I don't think it's got anything to do with that, though. It sounds more likely to me that some of your system files or possibly even your ASPI layer are causing the slowdown - this is certainly justified to me by a system restore seeming to cure these issues. You may want to watch that your drive isn't slipping into PIO mode (as opposed to the preferred DMA mode). I don't think a system restore would change this, but it might be worth looking into.
If in doubt, Google it. -
i have the same problem with dvd shrink. it started to slow down, then i reformated my computer and it went back to normal. now its starting to slow down again. nother problem i am having is i have to keep reinstalling it to get dvd shrink to start. once it is installed it will work finer but when i restart i have to installed it again....strange
How Big A Boy Are Ya? -
To make your dvd shrink run faster again. Double click on your C drive, local disk, double click on documents and settings, double click on all users. you will see a dvd shrink folder, open it and youll see all the analyzation reports you ran with shrink. Delete all the files. Thats what I did and it went faster again. (windows XP). someone posted this from way back and it worked for me. thanks
I can never find the files and I have XP. I followed your directions but did not find it. I looked everywhere too....no dice.
I found it. The post is https://www.videohelp.com/forum/viewtopic.php?t=241980&highlight=dvdshrink+documents+settings
I cleared out my DVDShrink files and BINGO....back to "Sir Speedy" for me. Mine were not in the exact same place though but the above link showed me what to look for.
Each analysis was saved to it's own hidden folder....and in that folder was a DVDShrink executable.
I must have placed the program in the wrong place or something.....that and my computer is German....the translations are hardly ever "word for word"...
Thanks for the links and advise guys. -
well i found my dvd shrink files and cleared it out. now my other problem is what would case dvd shrink to not load up when i click on it? i have to reinstall it everytime i reboot to get it to load.
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
KAV slowing down internet?
By Tbag in forum ComputerReplies: 0Last Post: 7th Jan 2009, 13:36 -
vcd audio slowing
By samdbl in forum Authoring (VCD/SVCD)Replies: 2Last Post: 11th Dec 2008, 22:11 -
slowing down a movie
By natty in forum Newbie / General discussionsReplies: 1Last Post: 27th Aug 2007, 06:51 -
ConvertXtoDvd slowing down ca. half way.
By BlackRose in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2007, 08:22
