  1. Hi
    I have a svcd file which is made out of dvd. the file plays fine on PowerDVD in other words on pc but when you burn it on 80min cd video freezes after 1-2 min. iam guessing its bad frames. but how do i fix it. Virtual Dub doesnt detect it
  2. Demux and re-mux the audio and video files with TMPG MpegTools for example. Then try again...
  3. Originally Posted by nirbhayn
    Hi
    Are you burning an authored SVCD (multiple files) or a data CD with just the .MPG file?
  4. Run it through VCDGear, fix mpeg. See if that helps.
    Cheers, Jim
    My DVDLab Guides
